JetCat P70 no propane flow during startup
I have a JetCat P70 that I have not started in a number of months. It is propane start and the last time I ran it, it started with no issues. I checked the glow plug which looks fine. I then disconnected the coupler after the gas valve and there is no propane flowing during the startup sequence. How do I test the valve and is there some
other troubleshooting or setup process I am missing. A new valve is $70+ so I dont want to purchase if that is not the issue. TIA.
Boomerang1 (05-15-2024)
Had an issue with Wren solenoids on an engine that had been out of service for a while, both solenoids not working.
Found I had to resolder both connections at the solenoid end, not sure why, it wasn't crash damage. All fixed now.
Springbok Flyer (05-16-2024)
